I'd like to understand better the API mode. In particular way:
-is it possible to write only "setup" (and no real code) into the sketch in order to permit still HS to manage input/output/etc? I know this could not be sense but I'd like to understand for the future.
-Is there still a maximum of 30 input as per standard HS mode?7
-If I want to write a code for 1wire sensor on an API board, in which way I have to dialogue with HS? Do I have to use "SendToHS(Device,Value)" every x time or HS can interrogate it?
Regards
Rinpe
Regards
Rinpe
