UltraSmtp3 (SMTP Email) HSPI for HS3
    Description
    UltraSMTP3 is a HomeSeer HS3 plug-in used to send reliable e-mail notifications. It can be used to send e-mail notifications using either the standard SMTP port or using SMTP authentication via SSL/TLS.
    How It Works
    • When you send an e-mail notification using UltraSMTP3, the e-mail is queued to disk and a unique queue identifier is assigned to the message. If a message cannot be sent to any of the configured SMTP mail systems, the messages is re-queued and retried until either the message is delivered or the user configurable delivery attempts are exceeded.
    • The UltraSMTP3 HSPI Send E-Mail action supports a wide range of HomeSeer replacement variables allowing the message to include information such as device details, global variables and HomeSeer logs lines.
    • Supports sending e-mail notifications using the standard SMTP port.
    • Supports sending e-mail notifications using authentication via SSL/TLS (e.g. gmail.com, hotmail.com, etc.)
    • Support for an unlimited number of SMTP server profiles.
    • Each message is assigned a queue identifier for tracking purposes.
    • An underlying database tracks the delivery status of each message.
    • Plain text or HTML message e-mail notifications are supported.
    • The body of the e-mail message can contain a wide range of HomeSeer replacement variables.
    • HomeSeer event trigger for e-mail delivery status of a message.
    • Error Try/Catch logic to ensure plug-in doesn't fail with an unhandled exception.
    • Multiple threading allows UltraSMTP3 HSPI to manage the delivery of e-mail notifications without disrupting the performance of HomeSeer.
    Example Usage
    • Use UltraSMTP3 plug-in to send e-mail notifications using any of the HomeSeer replacment variables in addition to several not supported by HomeSeer such as the last 5 lines of the HS log files, etc.
