Yet another mobile app
    Anybody using plugin with HomeTroller-SEL?
    Hi all,
    Has anyone successfully installed and run the plug-in in a HomeTroller-SEL? I've been testing on an Ubuntu VM, but I'm not sure how different is the Linux environment in the HT-SEL controller.
    If you have been able to run it in that controller, did you have to do anything other than installing the mono-devel package?
    -A
      Originally posted by avargaskun View Post
      Hi all,
      -A
      I am using a hometroller SEL and cannot get the plugin to initialize. See attachment.
        To close the loop: this issue has been fixed in the newest version of the plugin. Thanks weslew and MarkN for helping with the investigation.
        For those with a HomeTroller-SEL or Zee, please follow these steps before installing the plugin:
        1. Install mono-devel: sudo apt-get install mono-devel
        2. Install libsqlite3-0: sudo apt-get install libsqlite3-0
        Cheers.
          I keep seeing this error in the log:
          Apr-14 11:13:06 AM HSBuddy Method Capabilities does not exist in this plugin.
          Current Date/Time: 4/14/2017 11:16:08 AM
          HomeSeer Version: HS3 Pro Edition 3.0.0.318
          Linux version: Linux HS3 4.4.0-72-generic #93-Ubuntu SMP Fri Mar 31 14:07:41 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux System Uptime: 0 Days 0 Hours 4 Minutes 4 Seconds
          Number of Devices: 310
          Number of Events: 70
          Available Threads: 400
          Enabled Plug-Ins
          3.0.2.0: AquaConnect
          3.0.0.56: DSC Security
          3.4.316.2: HSBuddy
          3.0.0.103: HSTouch Server
          3.0.1.5: Kodi
          1.2.0.0: Monoprice Amp
          3.0.6280.35072: Ultra1Wire3
          3.0.0.63: weatherXML
          0.0.0.6: YAMAHA-RECEIVER
          3.0.1.110: Z-Wave
            Access to App
            There's a new version of app and plugin available for download
            iOS app: https://rink.hockeyapp.net/apps/55ad...99834344dcf288
            Avargaskun,
            Hi! I sent a PM to get access to the iOS app. Please let me know if you need any additional information. I'm really looking forward to using this.
              Version for Android 4?
              Is there still a version of this app available for Android 4? I would like to load this on a Wink Relay but it runs Android 4.3
                Is it possible to get a refresh or reload button. The app seems to get stuck on old data?
                  too late to become a beta tester?
                  avargaskun is it too late to become a beta tester? I have IOS
                    IOS APP
                    Interested in running the IOS APP - how to get it please.
                      Hi - I've just migrated to an Android phone and would be interested in trying this app. Is that possible?
                      Cheers
                      Edit - found the app, installed and working.
                      Will have a play and report back if any issues.
                        are notifications possible yet? Apple Watch compatibility?
                          So I received an email asking for my email address - however, when replying to it, it bounced with bad address. It said "sent from TapaTalk" if that helps.
                          Please try again - I would like to try the app. (IOS)
                            When looking under the beta section i don't see HSBUDDY listed there. I have also checked under every other tab just in case it got moved. Is there something I am supposed to do before it will be listed under the beta tabs? I am running HS3 pro on Windows platform. If you have any ideas please let me know. Thanks.
                              It was there until about a week ago, then it disappeared.
                                The plugin should now be back under the Beta section.
                                Sent from my Pixel using Tapatalk
