The function IsBlocked always seems to return true. I"m probably not using it correctly, and would like some advice as how to use it.
Returns TRUE even though that particular number is not listed in the blocked list.
Also is this syntax correct for using a variable for the number?
Thank you.
PHP Code:
hs.PluginFunction("BLNetCallerId", "", "IsBlockedCallerNumber", {"XXXXXX0467"})
PHP Code:
hs.PluginFunction("BLNetCallerId", "", "IsBlockedCallerNumber", {myNumber})
