I have used a dozen battery powered devices on my HS3 zwave network over the last few years. Each one has advertised that it passes on its battery level when it transmits. I currently have 6.
Not sure if this is a HS3 issue, device issue, or user issue. But since it has been the same experience for 2+ years and with different devices from different manufacturers, I am posting to the HS3 forum.
My observations:
* I do not *ever* recall seeing a value other than 100% or 0%.
* I have events set up to notify me when battery is below 25%. They have never been triggered. Yet I have replaced at least 2 batteries and today have another which is dead.
The devices I have set up right now are:
* Aeotec Gen 5 recessed door sensor
* Ecolink TILT-ZWAVE2 Garage Door Tilt Sensor
* Everspring water sensor
Do others have a better experience? If so, did you need to do anything in the device or in HS3 related to battery monitoring?
My observations:
