Hello,
I upgraded from 3.0.0.96 to 3.0.0.280 version last night and immediately noticed issues with command frequency. In summary, it appears that the same device is on a "timeout" period once a command is sent. It seems to be somewhere around 7-8 seconds for sequential commands to the same device .
1. a command is sent
2. a second command is sent almost immediately
3. the log shows "failed to send z-wave command to device xx"
4. the second command gets executed 7-10 seconds later or not at all.
is there a way to reduce the delay ? ideally to 0. This is causing issues with devices such as thermostats where a command sequence of set temp to x, set mode to auto is buffered and fails in 50% of the time...
if there is no artificial delay, does anyone have similar issues with .80 version of the z-wave plugin?
