Originally posted by jon102034050
View Post
zwave device status almost always incorrect
Originally posted by Kerat View PostIs this a Windows system? If so have you confirmed that power setting are set to high performance?
Originally posted by Rupp View PostWhat hardware are you running HS3 on? What does the CPU usage show?
Originally posted by jon102034050 View PostNo, I'm running this on Ubuntu 16.04.1. I'm not aware of any power saving settings in Ubuntu, but I'll look around
It's running on an i7 Intel NUC w/ 8GB of mem and a Corsair 512GB SSD. From what I can tell, the box doesn't seem to be at all stressed.
Ok, good news, to my knowledge Ubuntu does not enable OS power saving features out of the box.
Originally posted by Kerat View PostOk, good news, to my knowledge Ubuntu does not enable OS power saving features out of the box.
Another thing you might want to look at is USB power saving features. I wish I could get my HS3 system completely off of USB devices. Ideally it would all be IP so I could run it in a VM which I could backup regularly and stand up in a new host in minutes should things go pear shaped with my hardware. At any rate, People have reported problems with power saving feature in Windows for USB devices so if it were a situation you're experiencing you wouldn't be pioneering the situation.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by S-F View PostAnother thing you might want to look at is USB power saving features. I wish I could get my HS3 system completely off of USB devices. Ideally it would all be IP so I could run it in a VM which I could backup regularly and stand up in a new host in minutes should things go pear shaped with my hardware. At any rate, People have reported problems with power saving feature in Windows for USB devices so if it were a situation you're experiencing you wouldn't be pioneering the situation.
Sent from my SM-G930V using Tapatalk
Crossing my fingers.
Power saving features are almost always a mess, and it seems like everyone is trying it... M$, VMware, server hardware manufacturers... it only gets worse when you try to host services on systems with these settings enabled...
I cannot tell you how often I have ran into power saving features being at the root of a problem.
Sent from my iPhone using TapatalkLast edited by Kerat; November 30, 2016, 08:08 PM.
Originally posted by jon102034050 View PostGood to know, thanks. I'm using Ubuntu though, so it may not be relevant here.
Sent from my SM-G930V using TapatalkOriginally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
