Hi All,
Hi, I am trying to use the chromecast plug-in on my home network. At the moment all of the chromecast devices are found but I am struggling to just simply 'test' the connection through the plugin.
It is meant to say something like "this is a test message" but on a TV for instance, I can see the plug-in visually take over the TV, but no sound comes out. I've tested the speech through a local speaker and it works as well as wav files, but when attempting to use the chromecast plugin, I'm unsuccessful.
I followed the instructions on https://forums.homeseer.com/showthread.php?t=191073 but again it didn't work.
Any advice? There are issued found in the log too. Has anyone see this?
Mar-28 8:45:24 PM Error reading file C:\Program Files (x86)\HomeSeer HS3\html\Wave\chromecast20180328204524559.wav: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\html\Wave\chromecast20180328204524559.wav' because it is being used by another process.
Mar-28 8:45:24 PM Error In SpeakToFile: Exception from HRESULT: 0x80045040 Mar-28 8:45:12 PM Error reading file C:\Program Files (x86)\HomeSeer HS3\html\Wave\chromecast20180328204512102.wav: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\html\Wave\chromecast20180328204512102.wav' because it is being used by another process.
Mar-28 8:45:12 PM Error In SpeakToFile: Exception from HRESULT: 0x80045040 Mar-28 8:45:00 PM Error In SpeakToFile: Exception from HRESULT: 0x80045040
Can you help at all?
