Greetings,
I'm testing/debating to switch to Homeseer and I've installed the Chromecast plugin (needed for switching). The initial version installed and gave a zeroconf error "ERROR System.Exception: No Zeroconf providers could be found or initialized. Necessary daemon may not be running" As I said I'm new and using a trial of HS3 on windows. Once I find the actual log I can copy/paste if needed.
Do I need to assign a static IP to my Google Mini's? Or do I need to install zeroconf/bonjour or similar for this plugin to work?
