MeiHarmonyHub v3.0.3.13 is now available in the HomeSeer store and in the updater (Beta Section)!
This will be the last version before it goes to production release for the beta. I will be running extensive tests upgrading from 3.0.2.0 to this version to make sure updates from the last production version go well.
The following are included:
Please see the full descriptions here:
https://forums.homeseer.com/showthread.php?t=194095
Release notes Here:
https://forums.homeseer.com/showthread.php?t=194096
Request new Features Here:
https://forums.homeseer.com/showthread.php?t=194097
- Added MORE debug code around connection code to try and prevent plugin crashes.
- Fixed a bug around connecting where a failed connection would trigger as a forceful disconnect
- Changed default for inter-device commands to 500ms instead of 1ms (all existing installs will not be changed)
- Fixed bug where setting "Update Activity Device:" to anything other than "When Hub Updates Activity" meant the power off events from the hub weren't caught properly.
Release notes Here:
