Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Z-Wave Plug-in
HomeSeer Z-Wave Plug-in Discussions relating to the Z-Wave plug-in
Old January 12th, 2018, 06:11 PM
perranp perranp is offline
Viewer
Problem with AeoTec Nano Dimmer
Trying to include the nno dimmer to my network and it includes 8 devices out of 8 although it only shows up as a switch binary (on/off) in the child devices page.
Going to the Z-wave Node information page, a child device Switch Multilevel (Dimmable) is shown although no device parameters are editable (I want to change min/max level of dimming and also timings for going up or down.
How do I correct this?
Any suggestions?
Old January 12th, 2018, 06:47 PM
Rupp's Avatar
Rupp Rupp is offline
OverSeer
What version of the Z-Wave plugin are you running? Have you tried moving the device close to your Z-Wave interface and doing a rescan on the device?
-Rupp
Old January 12th, 2018, 07:02 PM
Viewer
Using latest beta 3.0.1.184 and latest HomeSeer Linux .368
Have not tried to move device closer as it´s installed 240V into the light switch socket, will shut down controller and move it to same room on Sunday to test reincluding/rescanning the device
Old January 14th, 2018, 05:31 PM
Viewer
New testing done
Now I´ve tested adding the node by moving the controller (pi) to a location where I actually could be within 2 inches of the device and the aeotec usb z-wave controller and it added securely but only 8 out of 9 devices were added.
Still doesn´t show up in the child devices list as "Switch Multilevel", but shows as this in the zwave node information (see below).
'Full Name: Node 16 Z-Wave Aeon Labs Switch Multilevel Polling: Polling Disabled
Manufacturer:
Aeon Labs Type:
0x3 ID:
0x6F Listens:
Yes Version: 4,38 (Unknown) Firmware: 1.2 Hardware: 111 Neighbor Count:
0 Speed:
100Kbps
Neighbors:
Last Working Route: Direct (100K) Set Route:
Uses Interface: Z-Wave (1) Basic Type: ROUTING SLAVE, Generic Type: SWITCH MULTILEVEL, Specific Type: POWER SWITCH MULTILEVEL
Command Classes:
Supported: Zwaveplus Info, Version, Manufacturer Specific, Device Reset Locally, Powerlevel, Security, Association, Association Grp Info, Switch Binary(V 1), Switch Multilevel(V 2), Switch All, Meter(V 3), Configuration, Clock, Notification(V 4), Scene Actuator Conf, Scene Activation, Firmware Update Md
Controlled: Hail
Supported Secure: Association, Association Grp Info, Switch Binary(Ver 1), Switch Multilevel(Ver 2), Switch All, Meter(Ver 3), Configuration, Powerlevel, Clock, Notification(Ver 4), Scene Actuator Conf, Scene Activation, Firmware Update Md, Device Reset Locally
Child Device: kW Hours CC: Meter Ver: 3 Polling: Polling Disabled
Child Device: Watts CC: Meter Ver: 3 Polling: Polling Disabled
Child Device: Volts CC: Meter Ver: 3 Polling: Polling Disabled
Child Device: Amperes CC: Meter Ver: 3 Polling: Polling Disabled
Child Device: Heat Notification CC: Notification Ver: 4 Polling: Polling Disabled
Child Device: Power Management Notification CC: Notification Ver: 4 Polling: Polling Disabled
Child Device: Switch Binary CC: Switch Binary Polling: Polling Disabled
Child Device: Switch Multilevel CC: Switch Multilevel Ver: 2 Polling: Polling Disabled
And all abilities to edit parameters are still greyed out.
HTML code is Off
Aeotec Nano Dimmer - Control 2 switches? airedale HomeSeer General Discussion Area 0 December 1st, 2017 12:58 AM
Help installing/controlling Aeotec Nano Dimmer Xyst HomeTroller-SEL 0 September 23rd, 2017 05:47 PM
Aeotec Nano Dimmer vs Fibaro Dimmer 2 decal HomeSeer Z-Wave Plug-in 4 June 19th, 2017 02:12 AM
Aeotec Nano Smart Switch Gen5 cgreig HomeSeer Wall Dimmers & Switches 0 May 20th, 2017 11:04 PM
Aeotec nano dimmer jogentry HomeSeer Z-Wave Plug-in 1 February 8th, 2016 01:54 AM
