I have purchased a PLM 2413UH and hooked it up to HS3 via USB. I have the Insteon PLM plugin installed, latest drivers installed and the correct COM port enabled.
I have a few SmartHome ApplianceLink V2 modules "Dual Band", first I linked the PLM with the ApplianceLink, then I went into HS and added a device via tap to add. This worked, as the ApplianceLink was in a socket next to the PLM.
However, I then moved to ApplianceLink to the next room. It doesn't work there, in fact it will only work in the same room as the PLM. I have ran the signal test in the plugin but they all fail. The test is 100% successful in the same room. Knowing they are both DualBand I figured it should at least get an RF signal and work.
So, reading documentation online, I pressed the button on the PLM 4 times until it went into Phase Detection Mode and starting beeping constantly. When I look at my appliance link, the LED never comes on solid, no matter which outlet I plug it into. According to documentation, this would mean all the outlets are on the same phase "Which I know is incorrect".
My only logical inference, is that RF is not working and I have sever signal degeneration... I have several Keypad lincs I want to install, as well as various Dimmer modules but I cant get any sort of signal outside of the room where the PLM is located...
Am I paring these things wrong, or doing something else wrong?
