Michael,
I have Sprinklers set up to get the ET from the CSV file created by VWS from my Davis Vantage Pro. On the "other Setup" page I have the the input selected as "CSV File" , the column entered as 26 and source reporting selected as "Daily Total".
When I look at the "General Status" page, the Daily ET always shows zero with the csv source in parens. The last update time always shows shortly after midnight on the current day. The hourly ET does update regularly, but I can't match that value to anything from VWS. (As I recall, at one time you were doing a calculation based of the daily ET for hourly ET HS sourced ET. Is that still correct?)
The CSV file location is correctly identified as all of the other values from the CSV file are updating correctly (e,g temp, wind, rain, etc.). And I have verified that the correct ET value is in column 26 of the CSV file.
I'm currently using MCSprinkers 2.7.204 and HS 2.1.0.11. However, this problem predated the update do hs .11 or MCSprinklers .204.
Thanks for your assistance (and for MCSprinkerls in general).
Cecil
Cecil
