Go Back   HomeSeer Message Board > Telephone,Text and Email Plug-ins > Telephone,Text and Email Integration Discussion > SMS Gateway (3P)
SMS Gateway (3P) Discussions related to the SMS Gateway third party plugin.
Old November 7th, 2016, 05:44 AM
petez69's Avatar
petez69 petez69 is offline
SMS plugin goes to sleep
Gavin
I've jsut upgraded the SMS plugin as part of housekeeping and I've found its been "going to sleep".
This seems to be only after the upgrade.
Can I get access to previous versions to do some testing ?
Appears that incoming there is nothing in the log at all...On outbound, I send a test event and then the incoming appears to be happy (how long for I dont know).
Plugin is currently at latest version, I suspect my older version was 12 months old ?
Thanks..Pete
Old November 7th, 2016, 07:33 AM
petez69's Avatar
Gavin
Appears the version that worked was 3.3.4..I found that after you made the changes to accomodate Regex parsing...
I jsut shutdown HS and restarted, the plugin showed no errors and there was no communicaiton errors in teh debug however it wasnt receiving txt messages. I rebooted the machine and it was all happy...the plugin detected the messages and deleted them as its supposed to on startup.
Tis odd/.//
Cheers..Pete
HS3 Plugin v3.1.2.0 - cannot set sleep duration JimBob SqueezeBox Plug-In (3P) 3 June 2nd, 2014 08:00 AM
Sleep on LAN? MeSteve HomeSeer General Discussion Area 17 June 19th, 2010 11:43 AM
Put PC to sleep codey HomeSeer General Discussion Area 2 April 7th, 2009 11:25 AM
Sleep mode cactsbob Motion Sensor Plug-In 1 March 12th, 2009 12:07 PM
does CAC run when DM is put into Sleep mode mnsandler Motion Sensor Plug-In 7 September 5th, 2008 07:28 PM
