I'm at a point where I need some help installing a WD100+ and two WA100+ switches. The results I'm seeing are that the LEDs on the WD100+ switch itself light up but the recessed lights they are connected to do not.
I'm trying to replace my existing switches within one WD100+ switch and two WA100+ switches. The current circuit controls a set of five recessed lights. I have a little experience with electrical work (i.e. changing existing switches, adding new single poles) I can easily wire single pole and 3-way switches. The 4-way is confusing to me. I'm totally lost trying to replace this 4-Way switch with Z-Wave switches!
My existing circuit looks like this:
If I'm not mistaken, the lights sit between the 3-Way switch near the patio and the 4-Way switch. Is there any way to confirm this? When I remove the hot wire from the switch near the patio, none of the other switches see any voltage.
I tried rewiring the circuit in the following way:
In the patio switch, I installed the WD100+. I pigtailed a white wire from the existing bundle of wires onto the WD100+.
At the 4-way switch location, I put a WA100+. At this location I connected the reds together and the whites together. I added a pigtail to both and connected a red and a white to the switch.
At the 3-Way switch near the garage I wired the red and white wires to the WA100+ and put a wire nut on the black and left it disconnected.
As I stated up above, the LEDs on the WD100+ light up, but the switch is not turning my recessed lights on. I was able to add the WD100+ to my SmartThings app as well.
I'm not sure if my current wiring will allow for me to use the HomeSeer switches. If that's the case I will need to return the unopened ones
Does anybody have suggestions on what I could try next? Any glaring issues with the way I tried wiring up the HomeSeer switches?
