Originally posted by rprade
View Post
Discussions related to HomeSeer Beta builds 3.0.0.369->3.0.0.423
Schlage Z-Wave Door Lock
I have a Schlage Connect Touchscreen Deadbolt that has been working fine up until I installed beta 3.0.0.420 and Z-Wave 3.0.1.202. Now the lock is no longer communicating with HS, I can't Audit it or get any connectivity. Before I rip apart everything it seems others are also having issues with locks, is my lock one of the affected?
How do I revert back to an older Z-Wave plug-in, I was using .200 before, I'd like to try that again?
HomeSeer Version: HS3 Standard Edition 3.0.0.420
Linux version: Linux Si-HomeSeer 4.9.0-6-amd64 #1 SMP Debian 4.9.82-1+deb9u3 (2018-03-02) x86_64 GNU/Linux
System Uptime: 3 Days 8 Hours 40 Minutes 44 Seconds
Number of Devices: 636
Number of Events: 266
Available Threads: 199
HSTouch Enabled: True
Event Threads: 1
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Anti Virus Installed:
Enabled Plug-Ins
3.0.0.12: AirplaySpeak
3.0.0.56: DSC Security
3.0.0.43: EasyTrigger
3.0.0.39: EnvisaLink
3.0.1.202: Z-Wave
Originally posted by numgis View PostI have a Schlage Connect Touchscreen Deadbolt that has been working fine up until I installed beta 3.0.0.420 and Z-Wave 3.0.1.202. Now the lock is no longer communicating with HS, I can't Audit it or get any connectivity. Before I rip apart everything it seems others are also having issues with locks, is my lock one of the affected?
HomeSeer attempted two-way communication with the node to test routing and was NOT successful - method used: MFG Information
The Z-Wave tab is just behaving very odd, clicking on the buttons either does nothing or something after a long delay. Other devices I don't have any issue with, only this one...
If I remotely lock/unlock the door I get the following in the log:
Mar-07 10:59:25 PM Z-Wave Setting device Door Lock to value 0
Mar-07 10:59:25 PM Z-Wave Set_New_Level, Parent: Z-Wave Node 159 IR Security Safety Entry Control, Child:Z-Wave Node 159 Door Lock
Mar-07 10:59:25 PM Z-Wave Set_New_Level_Real called for Z-Wave Node 159 Door Lock, Type=COMMAND_CLASS_DOOR_LOCK_V2, EndPoint=0
Mar-07 10:59:25 PM Z-Wave Set_New_Level_Real: Initial device is Z-Wave Node 159 Door Lock
If I try to Audit the node I only get this in the log:
Mar-07 11:03:56 PM Z-Wave Main Z-NET: Sending to node 159 (UnSecured) CC=COMMAND_CLASS_MANUFACTURER_SPECIFIC
Mar-07 11:03:54 PM Z-Wave Main Z-NET: Sending to node 159 (UnSecured) CC=COMMAND_CLASS_NO_OPERATION
Removed the old door lock node and got this in the log:
Mar-07 11:30:48 PM Error Calling PlugConfigDevicePost in plugin Z-Wave->Object reference not set to an instance of an object
Mar-07 11:30:44 PM Z-Wave Main Z-NET: Controller firmware version: 4.32
Mar-07 11:30:44 PM Z-Wave Main Z-NET: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
Mar-07 11:30:42 PM Z-Wave Main Z-NET: Node 17 was removed from interface Main Z-NET.
I'm also seeing a lot of these errors:
Mar-07 11:38:15 PM Z-Wave Error Main Z-NET: Exception transmitting to IP 10.10.10.61: Unable to write data to the transport connection: The socket has been shut down.
I'm testing .423 on a Zee2 and it's running great! Faster and smoother than before.
But:
I heard some rumors about a UseControl named "color" for integrating with Alexa and Google Home.
I can't seem to find it...?
Running on Windows 10 (64) virtualized on ESXi (Fujitsu Primergy TX150 S8).
Originally posted by rjh View PostThere has not been any changes in the lock support so I don't believe this is related to the build. Locks require very good communications so it sounds like communications or routing has changed in regards to these locks.
I re-optimised 3 time my z-wave network on node-1, did a full optimize now all Z-wave command seems to go through. Lock, unlock, get latest command works without z-wake error messages... Have no idea what happen since no devices were added since last december, no route changes, no network mdification othern than wiring my Z-net instead of using wifi on it. the only change to the system was upgrading to 420 last week end, that is where problem started with lock.
Originally posted by Moskus View PostI'm testing .423 on a Zee2 and it's running great! Faster and smoother than before.
But:
I don't know how you will get on doing it with the Tradfri plugin because the colours from Amazon are decided by them (so they decide what hex code is blue, red, green, yellow etc) and then this is passed to the colour control device so you might need some type of intermediary matching device that takes the amazon input and then translates it into the Tradfri fixed colours? Blue = Blue but there is no such thing with Alexa of Dark Peach which Tradfri supports so might need some translation? I'll leave that to yourself of course but I would be interested to know if you do decide on using this whether the colour picker appears in the events because on my install it doesn't whereas it certainly used to.
Noticing odd updating delays...updates fine but doesn't present updated plugins...just hangs...waiting....
if I leave the page and go back to it I think I see updater page but do not know if it is the current page.
[ATTACH]67331[/ATTACH]Last edited by Pete; March 8, 2018, 06:29 PM.- Pete
More odd Z-Wave errors never seen before updating to .420/.423 and .202. Is there something I can try, read something about backing up and then restoring my Z-NET interface to delete/recreate all routes? Will that retain all my devices or mess anything else up? If I want to roll back to an earlier Z-Wave Plug-in, how do I do that?
Mar-08 8:56:36 PM Z-Wave Error Device 678 is being set to an invalid value: 50
Mar-08 7:23:26 PM Z-Wave Error Failed sending Z-Wave command to device: Garage Lightning Garage Pot Lights
Mar-08 9:44:07 AM Z-Wave Error In Z-Wave application command handler: Index was outside the bounds of the array.
Mar-08 6:12:09 AM Z-Wave Error In Z-Wave application command handler: Index was outside the bounds of the array.
Mar-08 12:32:51 AM Z-Wave Error Device 76 is being set to an invalid value: 255
Mar-07 11:36:32 PM Z-Wave Error Main Z-NET: Exception transmitting to IP 10.10.10.61: Unable to write data to the transport connection: The socket has been shut down.
Mar-07 11:18:53 PM Z-Wave Error Device 622 is being set to an invalid value: 100
Mar-07 11:16:22 PM Z-Wave Error Failed sending Z-Wave command to device: Garage Door Lock Mudroom Door Lock
Mar-07 11:14:44 PM Z-Wave Error Device 872 is being set to an invalid value: 255
Mar-07 11:14:01 PM Z-Wave Error Failed sending Z-Wave command to device: Garage Door Lock Mudroom Door Lock
Mar-07 11:13:38 PM Z-Wave Error Device 678 is being set to an invalid value: 0
Mar-07 11:12:47 PM Z-Wave Error Failed sending Z-Wave command to device: Garage Lightning Garage Pot Lights
Mar-07 11:12:47 PM Z-Wave Error Failed sending Z-Wave command to device: Z-Wave Node 159 Door Lock
Mar-07 11:12:42 PM Z-Wave Error Failed sending Z-Wave command to device: Z-Wave Node 159 Door Lock
Mar-07 11:11:48 PM Z-Wave Error Device 76 is being set to an invalid value: 0
Mar-07 11:11:39 PM Z-Wave Error Failed sending Z-Wave command to device: Garage Door Lock Mudroom Door Lock
Mar-07 10:50:31 PM Z-Wave Error Device Z-Wave Node 159 IR Security Safety Entry Control Optimization and Add Route result could not be determined.
Mar-07 10:35:30 PM Z-Wave Error Main Z-NET: Exception transmitting to IP 10.10.10.61: Unable to write data to the transport connection: The socket has been shut down.
Mar-07 10:22:55 PM Z-Wave Error Main Z-NET: Exception transmitting to IP 10.10.10.61: Unable to write data to the transport connection: Connection reset by peer.
Mar-07 10:07:02 PM Z-Wave Error Main Z-NET: Exception transmitting to IP 10.10.10.61: Unable to write data to the transport connection: The socket has been shut down.
Mar-07 10:04:14 PM Z-Wave Error Main Z-NET: Exception transmitting to IP 10.10.10.61: Unable to write data to the transport connection: Connection reset by peer.
Mar-07 10:03:54 PM Z-Wave Error Failed sending Z-Wave command to device: Mudroom Lightning Mudroom Pot Lights
Mar-07 10:03:41 PM Z-Wave Error Failed sending Z-Wave command to device: Mudroom Lightning Basement Stair Lamp
Mar-07 10:03:28 PM Z-Wave Error Failed sending Z-Wave command to device: Basement Cold Room Exhaust Fan Cold Room Fan
Originally posted by rjh View PostI just posted build 422 which re-enables the log pruning and energy DB compaction. I don't believe those functions were causing any issues.
https://forums.homeseer.com/showthread.php?t=181241
Also, john did have a crash with the Z-Wave plugin, one I have never seen before but it pointed me to the function with the error and I have put in a fix, version 3.0.1.202.Last edited by John245; March 9, 2018, 09:14 AM.
Originally posted by numgis View PostIf I want to roll back to an earlier Z-Wave Plug-in, how do I do that?
Bill
