Do you see the RFX sensors using the xAP Viewer? Do the RFX Sensors look to be processed properly in the IO window or debug output?
I set it up to provide a message with each RF transmission. I would have thought that the transmission rate would be modest to conserve battery for these sensors.
I use two bsc classes. One is .info and the other is .event. I could send only .event messages to reflect only changes in the sensor value. This is the way I do things with most of my xAP things with the .info only comming upon request from a bsc query.
Another technique is to put a user-specified deadband zone so only changes outside this window would be transmitted. A third technique is to apply a smoothing algorithm so high frequency noise would be filtered.
Give me some guidance on what you thing would be best.
