OpenSprinkler control plugin available for download
    EDIT: This post contains the download for the HS2 version of the plugin. The HS3 version is available in another thread.
    I've just released a free plugin that allows control of the OpenSprinkler open source sprinkler controller.
    Features:
    • Simple install. One DLL and one INI file
    • Controls one OpenSprinkler controller with up to 88 valves total with expansion modules
    • Uses standard HomeSeer devices for control
    • Supports polling
    • Controller device reports status (Idle, Watering, Not Responding)
    • Supports watchdog timer so that valves do not stay open if HomeSeer crashes
    Support is available through this forum. Enjoy!
    Update 2/5/2013
    Version 1.1 now supports newer firmware versions that use the new javascript-based interface.
    Plugin and documentation are attached to this post.
