Hello I am having problems, please can someone help me with my code.
Error 3 Running script C:\Program Files (x86)\HomeSeer HS3\scripts\security.vb :Exception has been thrown by the target of an invocation.->Does entry point readytoArm exist in script? at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Obj ect obj, Object[] parameters, Object[] arguments) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at A.c17b105f989efe61e5979e67bec1ef734.cffd66cb0782c50126727e3f a75582d7a()
security.vb:
sonos.vb
Please note the ArrayList works when commenting the hs.runEx
Please note the bathroom|45|what possibly could go wrong|Normal works when testing in a manual event, the exception is that in an event in the parameters I don't use quotations "bathroom|45|what possibly could go wrong|Normal", I use: bathroom|45|what possibly could go wrong|Normal
Removing these didn't work.
Chris
security.vb:
' Speaks the list of Problems For Each valueOfArrayList As String In problemString hs.WriteLog("Security Script", valueOfArrayList) hs.runEx("sonos.vb","speakSomething","bathroom|45|what possibly could go wrong|Normal") Next
'--------------------------------------------------------------------------- ' Speak Method using Pipes to Seperate Values ( Speaker | Volume | TTS String | Voice ) '--------------------------------------------------------------------------- Sub speakSomething(ByVal Parms As Object) Dim parmArray() As String = Parms.ToString.Split("|")
Chris
