I heat my home with hot water in the floors, I'm not sure how common this is outside Scandinavia, but there you go. The system works like normal radiators, but the water goes in plastic pipes in the floors. I've recently upgraded my dumb controller with a Z-wave based Danfoss HC 10 and I'm now starting to fine tune the heating.
I'm currently using the system with normal thermostats, opening and closing the valves as needed. However, my wooden floors react slowly to temp changes, it takes 2 hours to increase 1 degree Celsius. So when the set point is reached, the heat will still increase in the room and increase beyond the set point.
How can I translate this into a variable I can use in programming my system? I'm not a programmer so all input is appreciated
