Description
UltraSighthoundVideo3 is a HomeSeer HS3 plug-in used to arm the security cameras connect to a Sighthound Video server. UltraSighthoundVideo3 also supports enabling Sighthound camera rules and triggering HomeSeer events based on motion triggers you define within your Sighthound Video server.
How It Works
Example Usage
Change Log
Version 3.0.5960.36744 - Released April 26, 2016
How It Works
- UltraSighthoundVideo3 HSPI polls the Sighthound Video server to determine the camera names, camera rules and the current arming status.
- UltraSighthoundVideo3 HPSI automatically creates a HomeSeer device for each camera connected to your Sighthound Video server.
- The latest snapshot from each camera is saved to disk and can be used to display within HSTouch.
- Automatically creates a HomeSeer device for each camera connected to Sighthound Video.
- Provides the ability to arm or disarm an individual camera or all cameras.
- Provides the ability to enable or disable Sighthound camera rules.
- Supports the ability to trigger a HomeSeer event based on rules defined within the Sighthound Video software.
- Supports a HomeSeer Email Camera Snapshot event action.
- Error Try/Catch logic to ensure plug-in doesn't fail with an unhandled exception.
- Multiple threading allows UltraSighthoundVideo3 HSPI to take simultaneous snapshots from your network cameras without disrupting the performance of HomeSeer.
Example Usage
- Use UltraSighthoundVideo3 plug-in to trigger a HomeSeer event whenever a rule within Sighthound Video triggers.
Change Log
- Fixed an issue with the Sighthound Video Motion Triggers greater than 2 digits.
