What is the range of Z-wave using Z-Net(s)? I am planning to use Z-wave for a few things I can't use UPB for. I hooked up a Z-Net but was unable to discover a HS HSM200 sensor about 40 feet away. Moved it to about 15 feet and still couldn't discover it. Moved it within 2 feet and discovered it. I know that each device serves as a repeater to enhance signal coverage but surely the range between two devices is more than 2 feet!
Z-Net range?
It is.
Here have no issues with a RPi2 / GPIO combo in the attic in my two story brick home. In the basement section (where everything is at) I have test Zigbee, Z-Wave controllers that also see anything connected to them. I have recently made a Leviton VRCOP serial controller a secondary to the HS3 RPi2 GPIO controller and really it is a primary for my OmniPro 2 controller and it sees everything that the attic controller sees.- Pete
I think it is the communication, not the range. Your interface might have been busy with other traffic and you hit it just right.
Sent from my SCH-R970X using TapatalkHS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Originally posted by DC View PostWhat is the range of Z-wave using Z-Net(s)? I am planning to use Z-wave for a few things I can't use UPB for. I hooked up a Z-Net but was unable to discover a HS HSM200 sensor about 40 feet away. Moved it to about 15 feet and still couldn't discover it. Moved it within 2 feet and discovered it. I know that each device serves as a repeater to enhance signal coverage but surely the range between two devices is more than 2 feet!
I ge easily 40-50 feet for direct communication and Z-Wave plus devices will go out to 75 feet without a problem. Other than the HSM200, Z-Wave plus devices can usually be included much further from the controller, I have been able to make it work 30 or more feet away. Older Z-wave devices are hit or miss on their inclusion range, depending on the ZDK version. It is always best to try to include a device within 6-10 feet of the controller, especially if it has a lot of interrogation for child nodes.
The HSM200 should include within 6-10 feet and communicate directly out to 30-40 feet.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
rmasonjr, I wouldn't think my interface is busy. There are no devices associated with it. I was trying to associate the first one.
rprade, by "discover" I mean add it to the network. I don't remember the exact error message but, basically, Homeseer couldn't see it until I moved it very close to the Z-Net. I thought a device shouldn't be moved after it's added to the network to preserve the "routing" information.
Also, after I added the Z-Net and one device, HS got VERY slow. Like 3-5 minutes to display a filtered list of devices. I have a lot to learn about Z-Wave but, so far, I'm not impressed.
I'll keep working with it for a couple of days but if it doesn't get better, I'll send it all back and punt on Z-Wave. I don't really enjoy tinkering with HA. I want it to work reliably after I set it up. I'm investing a LOT of time rebuilding my HS environment since I can't move my devices and events over from HS2 to HS3. With 525+ devices and over 300 events, that's a LOT of rework.
Originally posted by DC View Postrmasonjr, I wouldn't think my interface is busy. There are no devices associated with it. I was trying to associate the first one.
What are you using to run HS3 on?
I currently have 110 root Z-wave nodes and 1662 total devices. I have 1351 Events and 27 plug-ins. It is running on Windows 10 with a Xeon E3-1230 (3.30ghz) processor and 8gb of RAM. It takes about 2-4 seconds to build a new a filtered view. When running on a VM it takes about 50% longer to load a page.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
I'm running HS3 on a Lenovo PC, AMD 64-bit, 3.7 Ghz processor, 4 GB RAM, Windows 10 Pro. Not the beefiest computer but it ran HS2 extremely well. Very responsive and reliable. In fact, it's the fastest (for HS2) computer I've had, including a HomeTroller several years back. I'm going to add RAM if I can. Or I may replace it with a MUCH more powerful PC. You can get so much now for ~$500, there is no reason not to have a really good machine on which to run HS.
My Z-Wave network is one Z-Net, two HSM200s and one Fibaro multi-sensor. I'm just starting to experiment with Z-Wave. So far, I'm not impressed. The HSM200s aren't even usable. They don't detect motion in real time. I can poll the status and they send the motion status. Or I can unplug them and plug them back in and they send it. But if they are plugged in, I can walk right in front of them, or stand 4 feet away and wave my arms and ... nothing.
I'm sure I just don't have something configured correctly because HS couldn't sell them if they are that horrible. But, I haven't figured out what yet.
Originally posted by DC View PostI'm running HS3 on a Lenovo PC, AMD 64-bit, 3.7 Ghz processor, 4 GB RAM, Windows 10 Pro. Not the beefiest computer but it ran HS2 extremely well. Very responsive and reliable. In fact, it's the fastest (for HS2) computer I've had, including a HomeTroller several years back. I'm going to add RAM if I can. Or I may replace it with a MUCH more powerful PC. You can get so much now for ~$500, there is no reason not to have a really good machine on which to run HS.
Your computer should be plenty powerful. I chose the E3 Xeon and Supermicro server for low energy ~35-45 watts and IPMI remote management. Otherwise it is probably functionally about the same as yours. An SSD system drive made a big difference.
With regard to the HSM200, I don't have much confidence in them. I had an original from December 2014 that never worked right. It was difficult and unreliable to include, failed to report motion and luminance. It was replaced with a newer version a few months ago, it was difficult to include and doesn't report motion. I have had dozens of Aeotec multi-sensors that have all worked reliably.
You might take a look at the resource monitor and see if HS3 or HSPI_ZWave.exe are using a lot of resources.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Thanks for the information. I don't use my HS "server" for anything else.
I just ordered two Aeotec multi-sensors from the HS store. If they work better, I'll return the HSM200s. What I liked about them is they plug in so I don't have to worry about dead batteries. But, if they don't work, they're as worthless as if they had dead batteries.
