HomeSeer Mobile Beta 0.0.1
    #46
    Landscape/rotate mode not working on fire HD 10
    RJH-
    I have the app downloaded but notice that it does not rotate into a landscape view when tablet is in most common mounting position. Is this not just enabled "Yet" or a possible issue.
      #47
      Originally posted by supergolfstick View Post
      RJH-
      Please read the first post in this thread.......
      Jon
        #48
        I looked right over that bullet. Sorry!
          #49
          Delayed Response to actions on widgets in App
          RJH-
          I am seeing delays in execution of object selection in widgets. Simple function link switching a light from Off to On. In some cases I will see no response but after a few pushes, eventually the action executes. It is sporadic as some actions are very responsive and some are not. Compare this to web portal interaction, imperihome, etc.. No response delay at all.
            #50
            Very nice looking app. Good job! One issue that I see on my android smart phone (Samsung Galaxy Note8) is that when I added a Zigbee device to the dashboard, it added two of the devices. For a Z-Wave device, just one was added.
            Elliott
            "Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
              #51
              Still no love for us European HS users?
                #52
                Ok, I am guessing the the user/pass before the IP is the problem. That is my issue in HS, will put in a fix.
                Thank you.
                  #53
                  We enabled the app for most countries so you should be able to install now.
                    #54
                    Or iOS users. .
                      #55
                      What do you mean disable? Hide from mobile views?
                      See attached picture. The device is not set to hid from mobile view.
                      It may be related to a drop down list. All of my drop down lists appear to be doing this.
                        #56
                        This morning updated to the latest beta and installed the mobile app.
                        The MyHS login method doesn't appear to work it logins, but returns me to the main login prompt.
                        If I use the IP method. I get "Object reference not set to an instance of an object" error
                          #57
                          I assume the login works ok when you use HS3Touch mobile app? If so, does your password have some non alpha chars in it? If so, can you simplify it to just alpha chars to see if that is the issue?
                            #58
                            Is,it prompting to send feedback? If so, please submit it.
                            It's not. It just crashes out when trying to login. If I connect to the local IP using the functionality on the dot-menu, I can get it to load without login but I get "error loading devices". No prompts to submit feedback.
                              #59
                              Thanks for letting us non-US users also try it!
                              I can log in via MyHS, but I can't get HS Mobile to download any devices. It just fails.
                                #60
                                We are working through the bug reports, and I can say that the device list issue is fixed. We will post an update once we get through them.
