Originally posted by mnsandler
View Post
Jun 19 Insteon HUB update 1016 will break the plugin
Originally posted by mnsandler View Postguys,
i got an email from my smarthome contact.
they implemented TLS 1.0 temporarily secure the unit. They plan to release another update in the 'near future' with TLS 1.2.
i might be able to mod the code to fix the temporary issue.
any insight would be appreciated
I received the dreaded "Your Insteon Hub is Scheduled to Receive Updates" email on Jun 18... I have been working a lot and getting home late and just totally forgot about it.
Concerning the updates, I was worried about this (we are all dead in the water) scenario earlier this year https://forums.homeseer.com/showthread.php?p=1359269
Earlier this year, I did not block the hub in my firewall from communicating with the outside world back then. For some reason, I was hopeful that these updates would produce positive results and possibly correct my random disconnect problem. Well I guess they did solve the problem, it is no longer randomly disconnecting...Billy
guys,
Insteon is going to push out ver 1015 code (labeled as 1016) to roll everyone back.
I guess all the calls workedMark
HS3 Pro 4.2.19.5
they are pushing the fix to me right now. i will report back with the timeframe they expect to push out the fix to everyoneMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postthey are pushing the fix to me right now. i will report back with the timeframe they expect to push out the fix to everyone
Mark,
Should we remove the https section from the ini for those of us that tried the beta? Should we downgrade back or just remove the http section
Late to the party, but thanks
I came home to find lights out of sync and frustration after rebooting, resetting the hub, and checking logs. I'd signed on to ask for suggestions and found the whirlwind of activity and the much much appreciated rollback.
Thanks guys. I'm going to run Wireshark overnight on the IP of the Insteon hub to see how the rollback is pushed. I'll then block any further updates.
Originally posted by mattz View PostI came home to find lights out of sync and frustration after rebooting, resetting the hub, and checking logs. I'd signed on to ask for suggestions and found the whirlwind of activity and the much much appreciated rollback.
Great idea. Please pass along the pcap or at least what you find out so we can all block in the future.
Sent from my iPhone using TapatalkMark
HS3 Pro 4.2.19.5
This fix worked for my hub. i now see the following fw entry
Firmware:1015 Build Jun 20 2018 15:40:43
i will post the timeframe when you can expect Insteon to push out the fixMark
HS3 Pro 4.2.19.5
Guys,
thanks for your patience with all this. Keep you affected Hubs online; i think the fix will get pushed out tonight. this is what i see when i log in locally
Firmware:1015 Build Jun 20 2018 15:40:43Mark
HS3 Pro 4.2.19.5
