RCS TZ43 Features
1. The TZ43 keeps track of hours of operation for a) Filters, b) Heater, and C) A/C. I'd like to use these for HS events to schedule maintenance. Can these values be exposed as seperate HS Device values?
2. The TZ43 has 3 modes: Run (Schedule), Hold, and Away. Is there a way for BLStat to switch from Run to Hold and Hold to Run? [I'm aware on On command will switch from Away to the last used Run/Hold mode and an Off will switch from Run/Hold to Away.]
3. Is there a possability of setting up the schedules in BLSTAT and then downloading them to the TZ43 for operation in Run mode. I'm planning on controlling a 2nd house via my main HS and I want it to have the Heating/Cooling operate even when the Internet connection goes down -- i.e. Central control and decentralized operation.
