I have two HVAC unit with separate schedules. One units has no issue with the scheduled changes, the other the set point does not update. At the thermostat early this morning I could see the setpoint being set then immediately revert back to the prior SP.
This continued until I put the STAT on hold and set the SP manually.
Oct-28 5:46:45 AM Device Control Device: 1ST FLOOR Living Room Thermostat Heat Setpoint to 71 F (71) by/from: CAPI Control Handler Oct-28 5:46:40 AM Device Control Device: 1ST FLOOR Living Room Theromastat Cooling Setpoint to 76 F (76) by/from: CAPI Control Handler Oct-28 5:46:40 AM Device Control Device: 1ST FLOOR Living Room Thermostat Heat Setpoint to 62 F (62) by/from: CAPI Control Handler Oct-28 5:46:35 AM Device Control Device: 1ST FLOOR Living Room Theromastat Cooling Setpoint to 75 F (75) by/from: CAPI Control Handler Oct-28 5:46:35 AM Device Control Device: 1ST FLOOR Living Room Thermostat Heat Setpoint to 71 F (71) by/from: CAPI Control Handler Oct-28 5:46:30 AM Device Control Device: 1ST FLOOR Living Room Theromastat Cooling Setpoint to 76 F (76) by/from: CAPI Control Handler Oct-28 5:46:30 AM Device Control Device: 1ST FLOOR Living Room Thermostat Heat Setpoint to 62 F (62) by/from: CAPI Control Handler Oct-28 5:46:25 AM Device Control Device: 1ST FLOOR Living Room Theromastat Cooling Setpoint to 75 F (75) by/from: CAPI Control Handler Oct-28 5:46:25 AM Device Control Device: 1ST FLOOR Living Room Thermostat Heat Setpoint to 71 F (71) by/from: CAPI Control Handler Oct-28 5:46:24 AM Z-Wave Device: 1ST FLOOR KITCHEN Vivaldi Watts Set to 0.586 (0.586 Watts) Oct-28 5:46:20 AM Device Control Device: 1ST FLOOR Living Room Theromastat Cooling Setpoint to 76 F (76) by/from: CAPI Control Handler Oct-28 5:46:20 AM Device Control Device: 1ST FLOOR Living Room Thermostat Heat Setpoint to 62 F (62) by/from: CAPI Control Handler Oct-28 5:46:15 AM Device Control Device: 1ST FLOOR Living Room Theromastat Cooling Setpoint to 75 F (75) by/from: CAPI Control Handler Oct-28 5:46:15 AM Device Control Device: 1ST FLOOR Living Room Thermostat Heat Setpoint to 71 F (71) by/from: CAPI Control Handler Oct-28 5:46:10 AM Device Control Device: 1ST FLOOR Living Room Theromastat Cooling Setpoint to 76 F (76) by/from: CAPI Control Handler Oct-28 5:46:10 AM Device Control Device: 1ST FLOOR Living Room Thermostat Heat Setpoint to 62 F (62) by/from: CAPI Control Handler Oct-28 5:46:05 AM Device Control Device: 1ST FLOOR Living Room Theromastat Cooling Setpoint to 75 F (75) by/from: CAPI Control Handler Oct-28 5:46:05 AM Device Control Device: 1ST FLOOR Living Room Thermostat Heat Setpoint to 71 F (71) by/from: CAPI Control Handler Oct-28 5:46:00 AM Device Control Device: 1ST FLOOR Living Room Theromastat Cooling Setpoint to 76 F (76) by/from: CAPI Control Handler Oct-28 5:46:00 AM Device Control Device: 1ST FLOOR Living Room Thermostat Heat Setpoint to 62 F (62) by/from: CAPI Control Handler
