Plug-In Description
    Plug-In Description
    • This plug-in allows you to have two-way communication between your KNX installation and your HomeSeer setup.
    • You can create HomeSeer devices that corresponds to the devices in your KNX installation.
    • The HomeSeer devices will be updated based on status updates from the KNX bus
    • Changing the status of your HomeSeer devices can then be used to send commands to the KNX bus (turning on/off lights, dimming, changing set points etc.)
    Manual with additional information can be found here
    Nicolai L
