Homeseer just announced the release of the Z-NET AU version (https://shop.homeseer.com/products/h...australian-uzb and https://shop.homeseer.com/collection...plus-interface)
Looking at the features and specs of the US vs AU there seem to be some significant differences. It looks like the AU version is the US box with an additional AU USB z-wave radio (see link above)
US Version:
Remote Z-Wave Interface for use with HomeSeer Software and HomeTrollers
Supports Z-Wave Plus (and older) Products
Ethernet (and WiFi) Connections Allow for Optimal Positioning in Home
Supports Network Wide Inclusion (NWI) for Easy Product "Pairing"
May be Used with Other Z-NETs in Larger Homes or for Secondary Residences or Outbuildings
Includes Highly Optimized Antenna for Superior Range and Performance
Includes Easy to Use Web-Based Management Features
Provides Easy Upgrade Path from Z-Trollers, Z-Sticks, SmartSticks and Most Other Z-Wave Interfaces
Case Includes Keyhole slots for wall mounting (with your hardware)
Specifications
Z-Wave Plus Certified
Protocol: Sigma Serial API
Built-in 500 Series Z-Wave Module
Includes ZDK 6.5x Z-Wave Library
Field-upgradable Firmware
Supports 908.42 MHz (US) Z-Wave frequency
UPC: 610585164310
AU Version:
There is nothing listed under the specifications for the AU version.
Does this mean the AU version is missing Z-wave plus and NWI? And it the AU version will not use the optimized antenna? If so then other than essentially using ethernet there are no real advantages over a z-stick 2.
Maybe some could clarify this for me?
Thanks, Marty.
US Version:
Specifications
UPC: 610585164310
AU Version:
Thanks, Marty.
