Since I have used 1.5, Homeseer will not execute "Bed Time Shut Down" until it triggers "Enable Security"
hs.TriggerEvent "Bed Time Shut Down"
hs.mediafilename = "c:\Program files\homeseer\sounds\waves.mP3"
hs.SetDeviceStatus "v6",2
hs.waitsecs 200
hs.TriggerEvent "Enable Security"
THIS IS THE FULL SCRIPT>>>>>>>>>>>>>&g t;>>>>
sub main()
dim i
' exit if voice recognition is not enabled
if hs.LastVoiceCommand="not enabled" then
exit sub
end if
hs.speak "OK, when do you want me to wake you up?"
' clear out the last used voice command
hs.LastVoiceCommand=""
' create voice commands
hs.AddVoiceCommand "fiveuh clock"
hs.AddVoiceCommand "six oh clock"
hs.AddVoiceCommand "sevenuh clock"
hs.AddVoiceCommand "eight oh clock"
hs.AddVoiceCommand "Let me sleep in"
hs.AddVoiceCommand "nevermind"
' wait for a voice command
do
i=hs.LastVoiceCommand
if i<>"" then exit do
hs.WaitEvents
loop
' check recognition here
select case i
case "fiveuh clock"
hs.EnableEvent "Wake UP at 5 am"
hs.DisableEvent "Wake UP"
hs.DisableEvent "Wake UP on Sunday"
hs.DisableEvent "Wake UP at 7 am"
hs.speak "OK, I will wake you at five oh clock tomorrow."
case "six oh clock"
hs.EnableEvent "Wake UP"
hs.DisableEvent "Wake UP at 5 am"
hs.speak "OK, I will wake you at six tomorrow."
case "sevenuh clock"
hs.EnableEvent "Wake UP at 7 am"
hs.speak "See you at seven uh clock"
case "eight oh clock"
hs.EnableEvent "Wake UP on Sunday"
hs.Speak "See you at eight o clock"
case "Let me sleep in"
hs.Speak "OK, sleep well"
case "nevermind"
hs.Speak "OK, event cancelled"
exit sub
case else
hs.speak "I did not hear you"
exit sub
end select
hs.waitsecs 200
end sub
hs.waitsecs 200
sub main()
dim i
exit sub
end if
do
hs.WaitEvents
loop
select case i
case "fiveuh clock"
case "six oh clock"
case "nevermind"
exit sub
case else
exit sub
end select
hs.waitsecs 200
end sub
