Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Insteon Plug-in
HomeSeer Insteon Plug-in Discussions related to HomeSeer's own Insteon Plug-in
Old December 9th, 2014, 09:27 PM
vdcneil vdcneil is offline
Insteon Plug In issues
I cannot get past this error. Where do I begin to troubleshoot?
Error:
** You do not have the I/O interface enabled in HomeSeer **
Insteon functions are only available when the I/O interface is enabled.
** Unable to communicate with the Insteon powerline interface ***
Please make sure the interface is configured correctly and restart the plug-in.
I have validated that I can login to my Insteon Hub directly from a Web Browser, but I don't know what the next step would be.
INSTEON Hub Details
Alert 2.6 YF
PLM:9C
Firmware:4.8A Build Feb 08 2013
For device control visit connect.insteon.com
User Manual
Technical Support
Old December 9th, 2014, 09:34 PM
sparkman's Avatar
sparkman sparkman is offline
If you're using the HST Insteon plugin, it only supports the devices listed here: http://board.homeseer.com/showthread.php?t=166457. You likely will need the Insteon PLM Plugin by Mark Sandler to use the hub.
Cheers
Al
Old December 9th, 2014, 10:21 PM
I worked out the issue. The problem was the Interface Port setting on the Main Insteon Configuration page was missing the IP address:Port. Once this was populated I had to restart the the System, then the Username and Password field appeared. Another restart and the Plug-In status is now "OK".
Old December 9th, 2014, 10:34 PM
mnsandler's Avatar
Insteon Overlord
glad you got it working. please post other issues related to my plugin in my forum. this one is specifically for the hs insteon plugin.
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire3 | RFXCOM | NetCAM | MyQ | BLRadar | BLDenon | Jon00 Charting
HTML code is On
Insteon PLM Plug-in is moving to a licensed plug-in mnsandler Insteon Plug-in (Mark Sandler) 19 September 22nd, 2010 09:33 PM
After updating Insteon plug-in: Unable to initialize interface Insteon :Either no lic slivko626 Insteon Plug-in (Mark Sandler) 1 October 15th, 2006 01:49 AM
X-10 Devices won't Dim using the Insteon PLC & Insteon Plug-In MattPond Insteon Plug-in (Mark Sandler) 23 June 14th, 2006 02:08 AM
Insteon X10 upgrade issues BillyBob Insteon Plug-in (Mark Sandler) 4 February 13th, 2006 11:11 PM
