Panel Offline
    Panel Offline
    Since upgrading to v3.0.2.5, my Ethernet Connection intermittently shows "Panel Offline" and the status of the zones are not updating.
    Also, the log file is empty - Program Files (x86)/HomeSeer HS3/Logs/OMNI.log
    -John
    -John
    The log should never be empty. Something else must be going on.
    Can you try disabling/re-enabling the plugin?
    Also, check the logs from the web interface at OMNI -> OMNI Logs
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      I disabled/re-enabled the plugin and the zone status has updated and the panel now shows online. I disabled/re-enabled the plugin yesterday and the panel went offline again later in the day.
      When I go to OMNI -> OMNI Logs and "Load Log" that is also blank.
        Hmmm.... Go into the OMNI config and make sure the log setting is on DEBUG. It's on the Configuration tab.
          When I turn on DEBUG, Logs are generated.
          2/19/2018 10:07:12 AM [2] [Zone [12] Temperature-->39]
          2/19/2018 10:07:12 AM [2] [Temperature Zone 12 changed status. Reading=[39.0]]
          2/19/2018 10:07:12 AM [2] [---->Auxillary]
          2/19/2018 10:07:12 AM [2] [UNSOLICITED: ExtendedStatus]
          2/19/2018 10:06:42 AM [2] [Zone [12] Temperature-->38]
          2/19/2018 10:06:42 AM [2] [Temperature Zone 12 changed status. Reading=[38.0]]
          2/19/2018 10:06:42 AM [2] [---->Auxillary]
          2/19/2018 10:06:42 AM [2] [UNSOLICITED: ExtendedStatus]
          2/19/2018 10:06:35 AM [2] [Logging set to DEBUG]
            ah - that looks better. Now, disable/re-enable the plugin and allow it to run and collect some info.
            I will say that panel disconnects are somewhat common for the OMNI and are usually fixed by using a 10/100 hub between the panel and your network, or by using a managed switch and setting it to 10mbps/Half Duplex. Click on the Help tab in the plugin config for more info.
              Set my port to 10mbs/HD. What about flow control; enable or disable?
              <style></style>
                <style></style>
                Disable it for now and let's see how that works.
                  As far as i can tell everything seems to be working fine now, I'm not sure what was happening.
                  I have always had a 10/100 hub between my panel and my network and I didn't make any other changes.
                  I will email my logs.
                  Thanks for all of the help,
                  John
                    John
                    Good! I did get your logs and everything looks fine. You have an impressive number of zones - I'm jealous!
