Originally posted by happnatious1
View Post
Discussions related to HS3 build 435
Yeah, my TextSeer has the same issue. Can't really see why. And the plugin works as intended, for TextSeer it's just the status message that isn't updated properly.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Running on Windows 10 (64) virtualized on ESXi (Fujitsu Primergy TX150 S8).
Originally posted by dmurphy View PostI'm running .435 for 5days+ with no apparent issues.
Then again I'm in "transition" to HS3 and I may have to exclude/include devices again to "clean" up the mesh.
I updated to .435 from .428 yesterday. I read all the post for both (so I thought), but I did not realize the upgrade to .435 removed the negative (-) from in front of the Longitude which then caused the sunrise and sunset to be reversed. I thought I had read this was fixed in .435.
I put the negative (-) sign back in and the sunrise and sunset are back to correct.
Did I miss something in the posts? Is putting the (-) back the correct way to fix this?
MichaelHS3Pro & HS4Pro on Win2012R2
Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-Wave
Originally posted by Jobee View PostI updated to .435 from .428 yesterday. I read all the post for both (so I thought), but I did not realize the upgrade to .435 removed the negative (-) from in front of the Longitude which then caused the sunrise and sunset to be reversed. I thought I had read this was fixed in .435.
Michael
Originally posted by jeubanks View PostIt's my understanding that .435 fixed the longitude issue where before the negative was not accepted in the field. There was a blip between one of the versions and .435 where if you had the negative it would then get removed, and another blip that it was again removed after a HS restart. But I think it is finally fixed in .435. I have restarted HS a couple of times now and longitude stays put.cheeryfool
I updated to 435 a few days ago and thought I wasn't having any issues. But I also couldn't figure out why some of my events were not working. I finally started looking and found any event that was utilizing time was broken. No errors in the logs, but no attempt to even try to run the event either. I was on 422 previous, and reverted back, and all is fine.
First screen shot is with 435. Second is 422. I am not sure where the time even came from on the events. Has anyone else noticed this?
Is Rich monitoring this thread? I have seen issues crop up by multiple people, and nothing from HS, but I also saw that he stated he has moved on from HS3 to other projects. So did something get released to the wild and not get monitored?Last edited by waynehead99; April 26, 2018, 10:28 PM.
Saw the time change edit come in the form of a settings add on change prior to V.435.
Then a change in V.435 which was not an edit to the settings rather a code change.
It was there where I went to edit the settings after seeing the sunrise / sunset values off on the top header of Homeseer 3.
I edited the time longitude and latitude and rebooted and all was fine. Note this was minutes after updating to V.435.
Tested both manual and automagic entries to cities to work fine.
I looked over my events last night and all appear to be running fine.- Pete
