Spud, thanks again for helping me work the bugs out. Just purchased the plugin today. It has been very reliable and consistent in my testing. Let's just hope bugzilla gets working on our requests. Will only make an already excellent plugin better!
Kodi/XBMC Plug-in - Beta Testing
Installing Beta
Having a hard time getting beta to come up in Updater. I have the updater_override.txt in the HS3 App folder, have the zip in the updates3/zips folder. I get the following error when "Update listing" is pressed in updater:
An item in the Updater is temporarily unavailable due to: The underlying connection was closed: An unexpected error occurred on a receive.
Originally posted by bearben25 View PostHaving a hard time getting beta to come up in Updater. I have the updater_override.txt in the HS3 App folder, have the zip in the updates3/zips folder. I get the following error when "Update listing" is pressed in updater:
Just want to check before updating. Xbmc team has released the beta version of XBMC 13 gotham and was wondering if the plugin will work with gotham or are there any issue with it. Has anyone attempted with gotham yet.
Cheers KenHSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Originally posted by kenrad View PostJust want to check before updating. Xbmc team has released the beta version of XBMC 13 gotham and was wondering if the plugin will work with gotham or are there any issue with it. Has anyone attempted with gotham yet.
Cheers Ken
I am using the plugin with Gotham and have been for a while, no problems
Cheers Ken
EDIT: Gotham has been tested and works great with this pluginLast edited by spud; July 7, 2014, 06:41 PM.
version 3.0.0.23
in version 3.0.0.23 attached to first post of this thread, I have added the possibility to let the XBMC plugin act as a Speak Proxy, so that speak actions can be automatically send as GUI notifications to XBMC instances.
To enable this feature go to the XBMC config page and set "Send Speak Actions as XBMC GUI Notifications" to yes.
If you have another plugin already acting as a speak proxy you may want to set "Forward Speak Actions to HS Speakers"to No, otherwise you may hear twice the notification on HS speakers
In your Speak action, you can target specific XBMC instances by using XBMC:<xbmc_instance_name> as the name of your speaker.
You can also use standard replacement variables like shown on the screenshot below:
Originally posted by kideon View PostBeen playing around with this, XBMC will only display the box for a moment and then not the entire string if it is too long. Any way to make the notification stay up longer until the message is complete?
Originally posted by kideon View PostAlso trying a script command from control panel the notification does not come up
