Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old June 14th, 2016, 02:40 PM
LouieD LouieD is offline
Plug-in doesn't see PLM or Hub, HomeSeer plug-in does
I've been using HomeSeer for years (software version) and decided to upgrade to a HomeTroller. Everything in my house is InsteOn. I can get it to work fine with the HomeSeer plug-in, but this plug-in doesn't see my PLM or my hub. Please help. Thanks!
Old June 14th, 2016, 02:55 PM
mnsandler's Avatar
Insteon Overlord
Please post a pic of the plugin config page. you must set the port correctly on this page
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old June 20th, 2016, 05:50 PM
Thanks Mark for your quick response! Sorry for my delayed response...Here is a snapshot. I hope the attachment uploaded.
Old June 20th, 2016, 06:51 PM
mnsandler's Avatar
Insteon Overlord
on the plugin config page, can you set the logging level to detailed, and restart the plugin, and then post the log snippet of the startup of the plugin
also do the same for the hub port. you should be using the ip address colon port (eg 192.168.1.20:25105
i would like to see how the plugin is responding to both interfaces.
Old June 20th, 2016, 09:10 PM
Ok, so I tried using the ip address for the hub like you suggested. It then asked for user name and password. When I looked at the log it showed that it wasn't accepting the info. Also, am I using the correct port for the USB? (/dev/ttyUSB0) that's what works for the HomeSeer plugin.
Old June 20th, 2016, 09:11 PM
snapshot of log
Old June 20th, 2016, 10:25 PM
snapshot of HomeSeer plugin log
Old June 21st, 2016, 06:14 AM
mnsandler's Avatar
Insteon Overlord
the hub username & pswd are on a sticker on the bottom.
the usb port looks right
please try updating to the latest beta available in the beta section in the Updater
Last edited by mnsandler; June 21st, 2016 at 06:16 AM. Reason: please try updating to the latest beta available in the beta section in the Updater
Old June 21st, 2016, 07:32 PM
Ok, updated the latest version and nothing. I tried the username and password on the bottom of the hub and I tried the username and password I entered in when set it up. Nothing.
Old June 21st, 2016, 07:34 PM
mnsandler's Avatar
Insteon Overlord
stick with the username/pswd on the bottom.
restart hs and post the startup log
Old June 21st, 2016, 08:25 PM
Well the good news is that HomeSeer now sees my hub! However now it won't let me into the managing page. It says I have to be a admin to access it and even though I'm logged in, I can't control any lights. All I did was restart HS!
Old June 21st, 2016, 08:37 PM
mnsandler's Avatar
Insteon Overlord
try the logout function on the Tools menu
Old June 21st, 2016, 08:54 PM
Yeah, I did that already. I love my HS2 so much better .....
Old June 22nd, 2016, 06:40 AM
mnsandler's Avatar
Insteon Overlord
i wonder of this is a HomeTroller issue. please report back what you find.
Old June 22nd, 2016, 05:49 PM
It was. Everything is now working. Thanks for your help!
Old June 22nd, 2016, 06:18 PM
mnsandler's Avatar
Insteon Overlord
can you provide more details of the issue?
Old June 22nd, 2016, 06:32 PM
HomeSeer couldn't give an explanation as to how I lost admin rights. Anyway they got into the CMD promt (Terminal for Macs) and removed whatever profile I had and we rebooted. That's really all they did. Works fine now. Thanks again Mark, really appreciate all your help!
Old June 23rd, 2016, 09:52 AM
mnsandler's Avatar
Insteon Overlord
well thanks for this. i'm sure it will help another hometroller user in the future.
i would be curious if you can now get the plm to work, but maybe you don't want to tempt fate.
Old June 23rd, 2016, 10:12 AM
Now that I'm using the Hub, I've noticed that for whatever reason, the Hub seems to work better at installing new devices than the PLM.
Old June 23rd, 2016, 10:33 AM
mnsandler's Avatar
Insteon Overlord
yah, that's fine. everyone's environment is a little different.
HTML code is On
Plug-in support on Linux (Plug-in authors please read!) rjh HS3 Plug-In Development 40 December 29th, 2017 11:30 AM
Compare/contrast ACRF(2) plug-in and RFXCOM plug-in? NeverDie ACRF Processor (3P) 1 November 12th, 2013 11:18 AM
Insteon PLM Plug-in is moving to a licensed plug-in mnsandler Insteon Plug-in (Mark Sandler) 19 September 22nd, 2010 09:33 PM
Temperature Plug-in Trial Code Doesn't Work lengle MCS Temperature 2 November 21st, 2003 10:50 AM
