Hub2 to program or not
    This has probably been asked before,
    Can you add devices to homeseer or do you have to add everything to hub2 first with Insteon app?
    I don't want Insteon Android app involved other than initial setup.
    you don't need the insteon app. You can just register the devices directly with the plugin. In fact, the plugin doesn't look for devices registered via the insteon app. Some people use the app and the plugin, and they have to register these devices in both places.
    Mark
    HS3 Pro 4.2.19.5
      Thank you Mark
      I think that's what happened with my excessive traffic problem. The app and your plugin may have been too much .
        You do have to register the hub2 with the app first to be able to access it
        right?
          not register it, but set it up on the config page. you need the local ip, port (probably 25105) and the username and pswd from the bottom (not your smarthome acct)
          Mark
          HS3 Pro 4.2.19.5
