Here is a first beta of the SIP plugin for HomeSeer 2.1.
- It is time limited : 15th of April
- It doesn't work with HomeSeer 1.7
- It doesn't work with HomeSeer 2.0
- It requires .Net 2.0 and HomeSeer 2.1
1) Download the msi here: http://www.stipus.info/download/hs/SipPluginSetup2.msi
2) Double-click the msi file, and Install the plugin to your HomeSeer 2 directory. It doesn't work if you choose another directory during install.
3) Edit HomeSeer 2\Config\hspi_sip.ini
You must set these parameters correctly before starting the plugin
4) Restart HomeSeer, and enable the plugin.
5) Have a look at the .vbs files in the Scripts subdirectory.
You can change anything in these scripts.
First script called is sip_incoming.vbs
It redirects to
- sip_admin.vbs if an admin caller id is recognized
- sip_unknown.vbs if the caller id is unknown
sip_unknown.vbs asks to leave a message, or enter your admin code.
Default admin code is 43210
sip_message.vbs and sip_message_review.vbs allow you to record a message, and listen to the recorded message. There is no mailbox system yet.
sip_admin.vbs is a choice menu
- 1 for Home Control redirects to sip_home_control.vbs
- 2 for Music redirects to sip_music.vbs
home_control.vbs shows you how to interract with HomeSeer device. From your telephone you can get HomeSeer device status or turn ON turn OFF devices.
sip_music.vbs just plays a sample .MP3. Please edit the path to a sample MP3 in the file, otherwise the communication will be terminated.
I'm now leaving for 2 days in about 20 minutes... I hope it works as I won't be able to answer questions now.
Have fun,
stipus
PHP Code:
[Settings]
Debug=true
DebugWait=0
[Account]
DisplayName=Your Name
UserName=Your phone number
AuthUserName=Your username
AuthPassword=Your password
DomainRealm=sip.your-isp.com
SipProxyServer=sip.your-isp.com
SipRegistrarServer=sip.Your-isp.com
It redirects to
Have fun,
stipus
