I can't get the JDS IRXpander working with my HS and searching the posts didn't turn anything much up in terms of discussion...
The documentation implies that it's a done deal, but I can't get anything to work.
I see entries in my HS log reading:
"IR Label file (config\irlbl.cfg) missing or corrupt, creating new file"
"IR Zone file (config\irzones.cfg) missing or corrupt, creating new file"
Done Initializing Infrared Interface
So it seems to be doing its thing...
Nothing is mapped automatically (which I recall from the help file somewhere that this was a design limitation) - fine.
But then when I try to learn I get the dialogue box that says, "Press ok to initiate the learn process... blah blah blah". I do that, and I can see the IRXpander responding, but I get no further input/feedback from HS.
Subsequently pressing the "T" button to test yields nothing either.
Am I missing a step or is this not active yet?
Jcd
_____________________________
HS running on dedicated Dell Precision 2.8Ghz P4 533FSB, 1GB 400Mhz RDRAM - HS v1.6.18 w/ AT&T Voices
SG running on dedicated Dell 4500 933Mhz P3, 512mb ECC RAM - SG v2.42d, IR-Xpander, 3 I/O-Xpanders.
SG Plug-in 0.1.90
Jcd
SG Plug-in 0.1.90
