I'd like to ping domain names using hs.ping to simplify some of my scripts and make them more reliable. Is this possible?
Can you use hs.ping to ping names
taffyTags: None
taffy
How would I ping Yahoo.com. I get this msg when I attempt to run the script below.
3/30/2002 9:31:58 AM~!~Info~!~ Script Error, File: pingname.txt: 380: in line 2
Sub Main
DSL = hs.ping("yahoo.com", 2)
If DSL=0 Then
MsgBox "Success"
Else
MsgBox "failed"
'hs.WriteLog "Ping", "Result is " & r
End If
End Sub
billjohnson395
If you do:
Host="www.yahoo.com"
DSL = hs.Ping(Cstr(Host))
You will get an error. If you put Yahoo in /etc/hosts:
Yahoo 66.218.71.89
Then try:
Host="Yahoo"
You should have success!
taffy
billjohnson395
