Thanks much Mark.
HomeSeer 200 Series Wall Switches Announced
Any chance of a reverse direction?
Originally posted by macromark View PostOur fan controller will work with 3-speed and 4-speed fans that are 2.5 amps or less. "Off" is not counted as a speed. By default, LED indicators will reflect the speeds. "High" will light up all LEDs (even for a 3-speed fan).Don
Originally posted by brianaker View PostIs the a plan for when the docs is weill be\ announced in the Z-Wave product supplies. Without those we can't tell much about the switch will do.
Thanks.
Originally posted by scorp508 View PostAw man... my enthusiasm just dropped significantly. :'(
Most of the places I was excited to put these into I can't (smart bulbs or switched outlets) or won't put dimmers in. Pretty please consider another model that is the WS with the WD LED setup.
Originally posted by donstephens View PostAny chance of a reverse direction?HomeSeer Version: HS3 Standard Edition 3.0.0.548
Guest
Will the hs-hd200+ have the same electronics and firmware for dimming? I have some recessed integrated LEDs that do not work with the 100+ and was wondering if I should give the 200+ a shot or if I should expect the same behavior as the 100+.
Originally posted by Lifeisafractal View PostWill the hs-hd200+ have the same electronics and firmware for dimming? I have some recessed integrated LEDs that do not work with the 100+ and was wondering if I should give the 200+ a shot or if I should expect the same behavior as the 100+.
Originally posted by Kiwi View PostIs there any chance these products would be available in NZ / Australia Voltage and frequency ?
Originally posted by jasonparallel View PostAre they compatible with the HS-WA100+?
Originally posted by dhennen View PostIn a three-way setup, will there be slave switches where the LEDs on the switch mirror the master?
I'm starting my build-out and would really love that feature.HomeSeer Version: HS3 Standard Edition 3.0.0.548
