HomeSeer Memory and CPU best performance
    I have a Virtual Machine where I can set number of processors and memory, what is the beat value that I can set for both memory and CPU to make the best of HomeSeer?
    Aldo
    Aldo
    This here is a good read : https://www.networkcomputing.com/clo...void/885581827
    Eman.
      What is nice about a VM is that you can adjust the properties relating to the number of processors and memory. IE: build one VM and run HS3 in it. Then copy the VM and change the properties on it to suite your needs. Personally I find that while HS3 is a 32bit application it runs faster in 64bit mode. (Linux)
      It is all relating to how much you do with HS3 relating to the number of plugins, hardware connections, scripts et al.
        That is a great question. I understand that depend on plugins and etc. but assuming that you have unlimited CPU and memory what should be the best values for HS3? Would 4 CPU and 16 GB be ideal or should be more?
        Aldo
          Aldo
          That would be more than adequate as many users use RPi units with 1GB of RAM and a 1.2 GHZ processor.
              Yeah here the HS3 Pro box runs in 64bit Ubuntu with 16Gb plus one Virtual Instance of Windows that I run with the four CPUs / 32 bit and give it 2Gb of RAM.
              On the Pine64 2 Gb computer HS3 Lite is running in 64bit Ubuntu server. Machine doesn't break a sweat.
              Testing running an embedded XP VM on a RPi2 with 1Gb of RAM. It runs but is slow.
              On another POE connected RPi2 multitasking a bunch of stuff.....ZWave remote, 1-Wire hub, Domoticz and NOAA satellite captures. Not sweating at all.
              Today too now you can get a Skylake based motherboard and stock maximum RAM is 32Gb which would make for a nice VM box.
              All though now the Intel CPU as we know it will need to be redesigned. The patches to the ill stuff slow down the CPUs tremendously from what I have read.
              Today read that the super fast gaming computers are flying off the shelf being today utilized for bit coin mining...
              Relating to the OP HS3 runs fine on any computer these days Intel, AMD or ARM based in Linux (Windows is limited to Intel or AMD unless you create a VM in an ARM based machine - which I thought was not possible).
