The RPI boots fine, and i can ssh into the box, but HS wont start, is there some internal command i can run to perform a reinstall without loosing all my settings? or can i do a manual backup from CLI and then do a reinstall with writing the image on the SDcard? When i disconnect the power, and reconnects the power, i can see that the z-wave adapter lights up and, so it seems ok. And sometimes when i power-cycle the HS3 RPI i can push a button on a controller, and 1 -one- command gets accepted, after that everything dies besides the RPI, i can still navigate via SSH etc. Any ideas on how to fix?
When i try to start HS manually from CLI i get this:
root@HomeTrollerZeeS2V3:/usr/local/HomeSeer# ./autostart_hs
Queuing plugin Z-Wave to load...
Connecting to server at 127.0.0.1...
Connected, waiting to be initialized...
Z-Wave Plugin: OS Type is Linux
update_control_file:/updates3/hs3linuxhs3zees2.txt
Error: Internal: The Internal interface did not respond to the request for the controller capabilities - it may be disconnected or malfunctioning (3).
