Hello,
Since 10 years, I use MCSSprinklers Pro like plugin Homeseer 2
I have only 3 solenoid valves driven by a rain8 X10-2 controlled by a CM11
As this CM11 is now down, I am looking for a replacement solution at the lowest cost to continue to drive watering via HS2 / MCSSprincklers.
What do you recommend? Can MCSSprinklers, for example, order Z-Wave relays?
Thank you
Michel Bernier
Thank you
Michel Bernier
