The plugin has stopped working. I have moved to ISY firmware 4.2.30 for z-Wave support. I have installed one Z-Wave device (Thermostat) and will be installing a second thermostat as soon as I get the better Antenna for ISY Z-Wave operation. The ISY appears to be working fine.
I get the following message during Homeseer startup:
Error Initializing Interface: ISY Insteon-> Index was ouside the bounds of the array.
The Insteon plugin does not show up on the web page so there is not much I can do. All The ISY devices show up on the device status page. The devices have the correct state. I can issue a command to a device which is obeyed, however subsequent commands to the same or a device that has been sent a command from the status page take minutes to be executed.
Do you believe this is a 4.2.30 problem? I need 4.2.30 for the Z-Wave support.
I just noticed the following in the Homeseer Log:
ISY Insteon ----> Watchdog timeout.
I reverted The ISY to 4.2.18 with the exact same result. I will remove the Z-Wave device and see what happens.
I removed the Z-Wave device (excluded It from ISY) and the Plugin once again works. The plugin no longer puts out the error during initialization, The ISY Insteon Status button once again appears on the Web page. The operation of the device page is still not correct. It is sluggish after the first change to a device. It is as iff it is in some sort of a loop and not handling the web page for a while, times out and then again handles the web page after about a minute.
Hope the above helps as I do depend on the ISY and do not wish to have to code something up to handle my simple needs.
While Homeseer and the plugin was running I re-enrolled the Z-wave thermostat. The following messages appeared in the log:
Warning: Trying to use capability 6 to get ID for device ZW002 Thermostat
Warning: Trying to use capability 5 to get ID for device ZW002 Thermostat
Warning: Trying to use capability 4 to get ID for device ZW002 Thermostat
Warning: Trying to use capability 3 to get ID for device ZW002 Thermostat
Warning: Trying to use capability 2 to get ID for device ZW002 Thermostat
Warning: Trying to use capability 1 to get ID for device ZW002 Thermostat
