I am in the process of upgrading from HS2 to HS3. I configured my X10 devices using the X10 tab.
When I control my X10 devices directly from the device management view, my devices respond. I also see the x10 commands in the logging.
When using a simple script to set the device values, using either: hs.SetDeviceValueByName("Woonkamer WK1", 0)
or
hs.SetDeviceValue("O2", 0),
I see the values change in my webpage, but the devices do not respond. And I don't see any x10 commands in the logging.
Do I something wrong?
I am using the X10 plugin from HomeSeer, (TI103) with a Xanura CTX35, via a Perle IP <=> RS232 interface. But I think the problem is somewhere between the software interface between the scripting and the x10 plugin..
or
