I'm using Philio-tech PAN06 in wall dual relay switch modules to control my lights.
http://www.philio-tech.com/products_insert_control.htm
I only use one of the outputs/device. They work as intended when controlled by a vera 3 controller of MiCasaVerde.
But with Homeseer3 and an Aeon Z-stick Gen 5 the following is happening:
SW1 turned ON in HS --> instantaneously icon SB1 ON, followed by icon SB3 ON --> lights ON (instantaneously with SB1) --> so OK
next
SW1 turned OFF in HS --> instantaneously icon SB1 OFF, followed by icon SB3 OFF--> lights OFF(instantaneously with SB1) --> so OK
next
lights turned ON manually using S1 input --> lights OFF --> icon SB3 OFF in HS, SB1 stays ON --> not OK
but
SB1 only gets updated to ON when polled
this I could be solved by automatic polling after a SB3 change, but it feels like a messy solution
even so...
when SB1 is turned ON in HS (SB1 ON and SB3 ON) and then the lights are turned OFF using S1 the status of SB3 changes to OFF, but NOT SB1, even after polling the device
If then the main device is polled (renamed "Office Parent") SB3 turns OFF again while the lights still stay ON (and SB1 still stays OFF as well). This is even more incomprehensible to me.
still following ?
I've also noticed there are 4 devices created for each module in Vera but only 3 controllable (and 2 non-controllable) devices in Homeseer.
the following post is related to something similar:
https://forums.homeseer.com/showthread.php?t=179370
I've added associations to group 2 and 3 as well, but that did not really change anything.
Same for changing parameter 1.
parameter 1 - selected end point - 1 byte - 1: Relay1&Relay2, 2:Relay1, 3:Relay2
any one else using Philio swithes?
lights are connected to NO1
Switch Binary 1 is renamed to "Office" in the screenshot attached.
next
next
but
even so...
still following ?
