I have a TINY 3 mode test setup so I can play before I star building the REAL network...
1 - Gen 5 Aeotec Z-Stick
2 - Leviton Plug-in lamp module
5 - Zoom 4-in-1 Sensor
Got 6 copies of the following message when I booted by system
1/6/2017 7:56:47 PM ~!~Z-Wave Error~!~Exception processing incoming secure message from node 5 : Object reference not set to an instance of an object.Startup Complete, 6 errors detected, check the log for more information.
Node 5 has 6 sub-items
(from Node Information)
Full Name: Node 5 Z-Wave Vision Sec Notification Sensor Polling: Polling Disabled
Manufacturer:
Vision Security Type:
0x2021 ID:
0x2101 Listens:
No Version: 4.05 (ZDK 6.51.6) Firmware: 5.1 Hardware: 1 Neighbor Count:
1 Speed:
100Kbps
Neighbors: 2
Uses Interface: Ninovan (1) Basic Type: ROUTING SLAVE, Generic Type: SENSOR NOTIFICATION, Specific Type: NOTIFICATION SENSOR
Command Classes:
Supported: Zwaveplus Info, Security, Version, Manufacturer Specific, Device Reset Locally, Association, Association Grp Info, Powerlevel, Battery(V 1), Notification(V 4), Sensor Multilevel(V 7), Configuration, Wake Up, Firmware Update Md
Supported Secure: Version, Manufacturer Specific, Device Reset Locally, Association, Association Grp Info, Powerlevel, Battery(Ver 1), Notification(Ver 4), Sensor Multilevel(Ver 7), Configuration, Wake Up, Firmware Update Md
Child Device: Home Security CC: Notification Ver: 4 Polling: Polling Disabled
Child Device: Battery CC: Battery Polling: Polling Interval: 12h, 0m, 0s
Child Device: Temperature CC: Sensor Multilevel Ver: 7 Polling: Polling Interval: 20m, 2s
Child Device: Luminance CC: Sensor Multilevel Ver: 7 Polling: Polling Interval: 20m, 4s
Child Device: Relative Humidity CC: Sensor Multilevel Ver: 7 Polling: Polling Interval: 20m, 6s
PS.... this is messy stuff... can I go back to X10 and HS2 (not really, but talk about technology shock!)
Manufacturer:
0x2021 ID:
0x2101 Listens:
1 Speed:
100Kbps
Neighbors: 2
Command Classes:
