Hey guys,
Ok, attempted to get everything from other threads, but no one seems to have the exact issue i'm facing, I am attempting to get my new Fibaro Dimmer 2 working with HS3. I am using Aeotec Z Stick Gen 5.
Basically I have managed to add it to the network on the stick. Which was easy. I have then managed to get Homeseer to recognise it as part of the network and I can see the switch in the device list.
However I cannot see any settings comes back blank, I have tried to rescan etc. Logs don't seem to say much. I am also unable to set the correct associations as it is disabled (See screen shots). Currently at a loss.
I have seen a few posts regarding the dimmer 2 and have implemented most things, some I did not fully understand. Such as remove from network and re add as a non-secure node. (But as I understand a switch is non-secure anyway isn't it? Not a security device as such)
