Sub Main(parms as object)
Dim DeviceStringCode AsString
DeviceStringCode = hs.DeviceStringByName("HAI Security")
hs.WriteLog ("Test",DeviceStringCode)
End Sub
I get the following errors when running the script. I have tried the script with and wihtout the room as part of the argument.
I also trife hs.DeviceString(169) with th edevice's reference number with the same results.
Jan-19 4:14:12 PM Error Compiling script C:\Program Files\HomeSeer HS3\scripts\DeviceString.vb: 'DeviceStringCode' is not declared. It may be inaccessible due to its protection level.
Jan-19 4:14:12 PM Error Compiling script C:\Program Files\HomeSeer HS3\scripts\DeviceString.vb: End of statement expected.
Jan-19 4:14:12 PM Error Compiling script C:\Program Files\HomeSeer HS3\scripts\DeviceString.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
End Sub
