Strange issue
    Strange issue
    Every time I (re)start HS, mcsSprinklers recreates a number of devices, which I don't use(see below). I hide these devices in HS, but after a restart they're un-hided again. I find this very irritating. Can these be solved ??
    10/13/2007 10:34:17 AM ~!~Database Item~!~Saving Device Inhibit Min Days Between Water
    10/13/2007 10:34:17 AM ~!~Database Item~!~Saving Device Inhibit Area 1 Specific
    10/13/2007 10:34:17 AM ~!~Database Item~!~Saving Device Inhibit Area 2 Specific
    10/13/2007 10:34:17 AM ~!~Database Item~!~Saving Device Inhibit Area 3 Specific
    10/13/2007 10:34:17 AM ~!~Database Item~!~Saving Device Inhibit Area 4 Specific
    10/13/2007 10:34:18 AM ~!~Database Item~!~Saving Device Inhibit Area 5 Specific
    10/13/2007 10:34:18 AM ~!~Database Item~!~Saving Device Inhibit Area 6 Specific
    10/13/2007 10:34:18 AM ~!~Database Item~!~Saving Device Inhibit Area 7 Specific
    10/13/2007 10:34:18 AM ~!~Database Item~!~Saving Device Inhibit Area 8 Specific
    10/13/2007 10:34:18 AM ~!~Database Item~!~Saving Device Inhibit Setup Incomplete
    10/13/2007 10:34:18 AM ~!~Database Item~!~Saving Device Inhibit Seasonal Shutdown
    10/13/2007 10:34:18 AM ~!~Database Item~!~Saving Device Inhibit Low Temperature
    10/13/2007 10:34:18 AM ~!~Database Item~!~Saving Device Inhibit Today-Tomorrow
    10/13/2007 10:34:19 AM ~!~Database Item~!~Saving Device Inhibit Browser
    10/13/2007 10:34:19 AM ~!~Database Item~!~Saving Device Inhibit Low ET
    10/13/2007 10:34:19 AM ~!~Database Item~!~Saving Device Inhibit Max Cycles
    10/13/2007 10:34:19 AM ~!~Database Item~!~Saving Device Inhibit By User
    10/13/2007 10:34:19 AM ~!~Database Item~!~Saving Device Predicted Rain
    Rien du Pre
    The Netherlands
    Using:
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
    I do not know what version of mcsSprinklers you are running, but when looking at the current source it will only create devices if Homeseer indicates that the device does not already exist. What version are you running?
      The latest..... Version 2.7.299
      And he recreates the devices 100 % of the time during restarts. I have this since a couple of weeks since I upgraded to the latest version...
      Rien du Pre
      The Netherlands
      Using:
      Plugin's:
        I can see the issue and is corrected. When I finish with other changes that are underway I will post the update.
          Okay thanks......
          Rien du Pre
          The Netherlands
          Using:
          Plugin's:
