For the longest time now when HS3 starts up I see the following in the console:
The Z-Wave2.db-journal file doesn't exist. Wondering if it might be a permissions thing, I checked the Data\Z-Wave folders and see that the folder shows up as "Read Only", though the files underneath it aren't. Tried changing that to read/write in case it was the issue, but it jumps back immediately to readonly. However, Homeseer has no problem creating/writing any other files, and everything is otherwise operating correctly. The errors are only on startup, and are just annoying.
Any ideas?
9/12/2017 9:24:23 AM ~!~Z-Wave Error~!~GetConnection error Access to the path 'C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db-journal' is denied. 9/12/2017 9:24:23 AM ~!~Z-Wave Error~!~ERROR, Z-Wave Data object 0 failed to be updated or added to the database. 9/12/2017 9:24:23 AM ~!~Z-Wave Error~!~GetConnection error Access to the path 'C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db-journal' is denied. 9/12/2017 9:24:23 AM ~!~Z-Wave Error~!~ERROR, Z-Wave Data object 0 failed to be updated or added to the database. 9/12/2017 9:24:24 AM ~!~Z-Wave Error~!~GetConnection error Access to the path 'C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db-journal' is denied. 9/12/2017 9:24:24 AM ~!~Z-Wave Error~!~ERROR, Z-Wave Data object 0 failed to be updated or added to the database. 9/12/2017 9:24:25 AM ~!~Z-Wave Error~!~GetConnection error Access to the path 'C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db-journal' is denied. 9/12/2017 9:24:25 AM ~!~Z-Wave Error~!~ERROR, Z-Wave Data object 0 failed to be updated or added to the database. 9/12/2017 9:24:26 AM ~!~Z-Wave Error~!~GetConnection error Access to the path 'C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db-journal' is denied. 9/12/2017 9:24:26 AM ~!~Z-Wave Error~!~ERROR, Z-Wave Data object 0 failed to be updated or added to the database. 9/12/2017 9:24:26 AM ~!~Z-Wave Error~!~GetConnection error Access to the path 'C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db-journal' is denied. 9/12/2017 9:24:26 AM ~!~Z-Wave Error~!~ERROR, Z-Wave Data object 0 failed to be updated or added to the database. 9/12/2017 9:24:28 AM ~!~Z-Wave Error~!~GetConnection error Access to the path 'C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db-journal' is denied. 9/12/2017 9:24:28 AM ~!~Z-Wave Error~!~An attempt to check for Z-Wave Scene (HomeID/Name=DB46E657/ManualScene_5) returned an error. 9/12/2017 9:24:28 AM ~!~Z-Wave Error~!~ERROR, ZWave Scene ManualScene_5 failed to be updated or added to the database.Startup Complete, 15 errors detected, check the log for more information.
Any ideas?
